    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Fix Windows 10 Update Issues
OMEN by HP 15-dc1004ua Product Specifications
6VM28EA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (1 x 16 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
2.41 kg
200 W AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 4 hours and 45 minutes
Video Playback Battery life
Up to 3 hours
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
FreeDOS 1.2
