    Are you working from home?
    Fix Windows 10 Update Issues
OMEN by HP 15-dc1005ua Product Specifications
6VS09EA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (1 x 16 GB)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
2.41 kg
200 W AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 5 hours and 15 minutes
Video Playback Battery life
Up to 2 hours and 45 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
FreeDOS 1.2
