    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
    Fix Windows 10 Update Issues
HP ENVY X360 - 13-ar0607nz Product Specifications
6QE86EA
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ Vega 8 Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 headphone/microphone combo
30.6 x 21.2 x 1.47 cm
1.3 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Battery life mixed usage
Up to 14 hours and 30 minutes
Video Playback Battery life
Up to 11 hours and 30 minutes
Bang & Olufsen, quad speakers, HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
