    Apache Log4j Update
HP Pavilion 15-cs2013ms Product Specifications
6SE69UA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
  • 128 GB M.2 SSD
  • [16]
Optical drive
Optical drive not included
15.6" diagonal HD SVA micro-edge WLED-backlit touch screen (1366 x 768)
802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only, 5 Gb/s signaling rate); 1 AC smart pin
36.16 x 24.16 x 1.79 cm
1.85 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Video Playback Battery life
Up to 8 hours and 30 minutes
B&O, dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP BIOS Protection
