    Apache Log4j Update
HP Pavilion Gaming Laptop 15-cx0017tx Product Specifications
4DR19PA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
36.5 x 25.65 x 2.54 cm
Starting at 2.17 kg
135 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Pre-installed software
iQiyi
