    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
    Fix Windows 10 Update Issues
HP Pavilion 15-cs2011ur Product Specifications
6PR98EA
Intel® Core™ i7 8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
36.16 x 24.56 x 1.79 cm
1.85 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours
Video Playback Battery life
Up to 9 hours
