    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion 14-ce1010nl Product Specifications
6VL75EA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics 620
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Pointing device
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo
32.68 x 22.17 x 1.79 cm
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Video Playback Battery life
Up to 8 hours and 45 minutes
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
