    Fix Windows 10 Update Issues
    Are you working from home?
HP Stream 14-cb112nl Laptop PC Product Specifications
6VQ89EA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 600
64 GB eMMC
Optical drive
Optical drive not included
14" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4; 1 headphone/microphone combo
33.7 x 22.6 x 1.79 cm
1.44 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP Webcam with integrated digital microphone
Dual speakers
Windows 10 Home in S mode
HP Audio Switch; HP JumpStart
Pre-installed software
Netflix
Office 365 Personal 1-year
