HP 27f 27-inch 4K Display Product Specifications
Panel
5ZP65AA
Display panel type
IPS with LED backlight
27"
Panel active area (W x H)
59. 67 x 33.56 cm
Resolution
4K UHD (3840 x 2160 @ 60 Hz)
Aspect ratio
16:9
Viewing angle (typical)
178° horizontal
Brightness (typical)
300 cd/m²
Contrast ratio (typical)
1000:1 static; 10000000:1 dynamic
Response times
5 ms gray to gray
Pixel pitch
0.155 mm
Display features
Anti-glare; Language selection; Plug and Play; User controls; Height adjustable
Onscreen controls
User controls
Brightness; Color control; Contrast; Exit; Image control; Information; Input control; Language; Management; Menu control; Power control
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1366 x 768; 1440 x 900; 1600 x 1200; 1600 x 900; 1680 x 1050; 1920 x 1080; 1920 x 1200; 2560 x 1440; 2560 x 1600; 3840 x 2160; 640 x 480; 720 x 400; 720 x 480; 800 x 600
Video/other inputs/cables
Interface
HDMI; DisplayPort
Display Input Type
1 DisplayPort™; 2 HDMI
Ergonomics
Tilt and swivel angle
Tilt: -5 to +16°
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
42 W (maximum), 38 W (typical), 0.3 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
61.36 x 19.36 x 50.13 cm
Dimensions (W x D x H)
61.35 x 4.02 x 36.64 cm
24.16 x 1.58 x 14.43 in
Product dimensions with stand (W x D x H)
24.16 x 7.62 x 19.74 in
3.5 kg
What's in the box
What's in the box
AC power cord; DisplayPort™ cable; HDMI cable; Warranty card; QSP; CD; Monitor; AC power cable; Telephone card
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
-20 to 60°F
Operating humidity range
20 to 80% RH
Environmental
Arsenic-free display glass; Low halogen
Certifications and compliances
BSMI; CB; CCC; CE; China Energy Label (CEL); CSA; CSA-NRTL; EAC; E-standby; EUP Lot-6; FCC; GEMS; HRN N N0.201; ICES; IS 1121; ISO 9241-307; KC; KCC; RCM; SABS IEC 60950-1; SASO; TUV Bauart; VCCI; ES7.0; EUP Lot 26; MEPS (HP) UKRAINIA; IEC60950:1999; PSBISC
