    Fix Windows 10 Update Issues
HP P174 17-inch Monitor Product Specifications
Panel
5RD64AA
Display panel type
TN with LED backlight
17"
Panel active area (W x H)
33.79 × 27.03 cm
Resolution
SXGA (1280 x 1024 @ 60 Hz)
Aspect ratio
5:4
Viewing angle (typical)
160° vertical; 170° horizontal
Brightness (typical)
250 cd/m²
Contrast ratio (typical)
1000:1 static; 10000000:1 dynamic
Response times
5 ms on/off
Pixel pitch
0.264 mm
Display features
Anti-glare; LED backlights; On-screen controls; Plug and Play
Onscreen controls
User controls
Brightness; Color control; Contrast; Exit; Image control; Information; Management; Menu; Power
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
VGA
Display Input Type
1 VGA
Ergonomics
Tilt and swivel angle
Tilt: -5 to +25°
VESA mount
VESA mount compatible
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
179 W (maximum), 141 W (typical), 0.5 W (standby); 13 W (maximum), 12 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
37.48 x 19 x 38.59 cm
Dimensions (W x D x H)
37.48 x 5.07 x 31.23 cm
14.76 x 1.2 x 5.98 in
Product dimensions with stand (W x D x H)
14.76x 7.48 x15.19 in
2.6 kg
What's in the box
What's in the box
AC power cord; Documentation; VGA cable; QSP
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% RH
Environmental
Arsenic-free display glass; Low halogen; Mercury-free display backlights; TCO Certified
Certifications and compliances
Argentina S-Mark; Australia MEPS; BIS; BSMI; CB; CCC; CE; CEL; China CECP; cTUVus; E-standby; FCC; ICES; KC/KCC; KCC; RCM; SEPA eco label (China); Taiwan Green Mark; TCO Certified; TUV LBL; TUV/GS; VCCI; Vietnam MEPS; ISC; IEC 62368; California Energy Commission (CEC); Mexico safety; ES7.1
