Product Specifications for the HP OfficeJet Pro 9026 All-in-One Printer (3UL00D)
Product naming
Model name
3UL00D
What's included and accessories
What's in the box
HP OfficeJet Pro 9026 All-in-One Printer; HP 965 Setup Black Ink Cartridge; HP 965 Setup Cyan Ink Cartridge; HP 965 Setup Magenta Ink Cartridge; HP Setup 965 Yellow Original Ink Cartridge; No CD Flyer; Ink Caution Flyer; Power Cord; Setup Poster; Reference Guide; Warranty Card
Accessories
None
Connectivity
Ports
1 USB 2.0; 1 Host USB; 1 Ethernet; 1 Wireless 802.11b/g/n; 2 RJ-11 modem ports
Wireless capability
Yes
Copy
Copier settings
Copies; Two-Sided; Lighter/Darker; HP Copy Fix; ID Copy; Resize; Quality; Paper Size; Paper Type; Collate; Margin Shift; Crop; Copy Preview; Tray Select; Enhancements
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
Up to 39 cpm
Copy speed, black (draft, Letter)
Up to 39 cpm
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
7.0 B(A) (printing at 21 ppm)
Acoustic pressure emissions
53.5 dBA (printing at 20ppm) (operator position)
Recommended operating humidity range
25 to 75% RH
Recommended operating temperature range (Celsius)
15 to 32°C
Storage temperature range (Celsius)
-40 to 60°C
Fax
Fax available
Yes, color
Fax features
Digital Fax - Fax to PC is available with Windows (Please use: Visit http://www.hp.com/support to download the latest software.)
Fax Resolution Black (best)
Up to 300 x 300 dpi
Fax memory
Up to 100 pages
Telephone handset supported
No
Fax telephone mode supported
No
Modem
Synaptics Troy modem; data rate up to 33.6 kbps
Fax Speed Dials, Maximum Number
Up to 99
Fax transmission speed (letter)
4 sec per page
Fax transmission speed note
Based on standard ITU-T test image #1 at standard resolution. More complicated pages or higher resolution will take longer and use more memory.
Memory
Memory
512 MB
Maximum Memory
512 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Wi-Fi® Direct Printing; Mopria™ Certified; HP Smart
Mobile printing compatibility note
Wireless operations are compatible with 2.4/5 GHz operations only. App or software and HP ID account registration may also be required. Some features require purchase of an optional accessory. Learn more at http://hp.com/go/mobileprinting.
Networking
Network protocols, supported
9100, LPR, SNMP, SLP, Internet Printing Protocol (IPP), WS-Print, Wireless
Paper handling
Input capacity
Up to 250 sheets
Standard input capacity (cards)
Up to 50 sheets
Standard input capacity (envelopes)
Up to 30
Standard input capacity (secondary tray)
Up to 250 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6; B5 (JIS); Envelope (DL, C5, C6, Chou #3, Chou #4); Card (Hagaki, Ofuku Hagaki)
Media sizes, custom (metric)
Tray 1: 76.2 x 127 to 215.9 x 355.6 mm
Media types
Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, Other Photo Inkjet Papers, Other Matte Inkjet Papers, Other Glossy Inkjet Papers, Thick Plain Paper, Light/Recycled Plain Paper, HP Tri-fold Brochure Paper, Glossy
Media weight supported (metric)
60 to 105 g/m² (plain); 220 to 280 g/m² (photo); 75 to 90 g/m² (envelope); 163 to 200 g/m² (card)
Borderless printing
Yes, on photo paper only, up to 8.5 x 11 in (US letter), 210 x 297 mm (A4)
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Physical dimensions
Maximum dimensions (W x D x H, metric)
437 x 519.8 x 318.3 mm
Weight (metric)
12.02 kg
Power
Energy savings feature technology
Schedule On and Schedule Off
Internal (Built-in) Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz
Power consumption
0.13 watts (Manual-Off), 5.80 watts (Ready), 1.22 watts (Sleep)
Print cartridges
Number of print cartridges
4 (1 each black, cyan, magenta, yellow)
Replacement cartridges
HP 965 Black Original Ink Cartridge (~1,000 pages) 3JA80A; HP 965 Cyan Original Ink Cartridge (~700 pages) 3JA77A; HP 965 Magenta Original Ink Cartridge (~700 pages) 3JA78A; HP 965 Yellow Original Ink Cartridge (~700 pages) 3JA79A; HP 965XL Black Original Ink Cartridge (2,000 pages) 3JA84A; HP 965XL Cyan Original Ink Cartridge (1,600 pages) 3JA81A; HP 965XL Magenta Original Ink Cartridge (1,600 pages) 3JA82A; HP 965XL Yellow Original Ink Cartridge (1,600 pages) 3JA83A; HP 969XL Black Original Ink Cartridge (3,000 pages) 3JA85A. Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic (standard)
Print speed (black, draft, Letter)
Up to 39 ppm
Print speed (color, draft, Letter)
Up to 39 ppm
Print speed black (ISO)
Up to 24 ppm
Print speed color (ISO)
Up to 20 ppm
Print resolution (best)
1205 x 1200 rendered dpi
Maximum print area (metric)
216 x 356 mm (Legal)
Monthly duty cycle
Up to 30,000 pages
Print languages
HP PCL3 GUI
Printer smart software features
Orientation: Portrait/Landscape; Print on Both Sides: None/Flip on Long Edge/Flip on Short Edge; Page Order: Front to Back/Back to Front; Pages per Sheet: 1, 2, 4, 6, 9, 16; Quality Settings: Draft/Normal/Best; Printing Shortcuts; Print in Grayscale: Off/High Quality Grayscale/Black Ink Only; Pages per Sheet Layout: Right then Down/Down then Right/Left then Down/Down then Left; Print in Max DPI: No/Yes; HP Real Life Technologies: Off/On; Booklet: None/Booklet-Left Binding/Booklet-Right Binding; Pages to Print: Print All Pages/Print Odd Pages Only/Print Even Pages Only; Borderless Printing: Off/On; Page Borders: Off/On
Regulatory specifications
Regulatory model number
SNPRC-1803-01
Safety
UL 62368-1: 2nd Edition
Electromagnetic compatibility
CISPR 32:2012/EN 55032:2012 Class B; CISPR 24:2010/EN 55024:2010; EN 61000-3-2:2014; EN 61000-3-3:2013; FCC CFR 47 Part 15 Class B (USA); ICES - 003, Issue 6 Class B (Canada); EN 301 489-1 (V2.1.1:2017), EN 301 489-17 (V3.1.1 2017)
Telecom compliance (fax capability)
USA: TIA-968-B-3, TIA-1096-A; Canada: IC CS-03 Part 1 Issue 9 Am5, Mar 2016 and IC CS-03, Part 8 Issue 9 Am5, Mar 2016; EU: ES 203 021-2, ES 203 021-3; EU: Radio Equipment Directive 2014/53/EU; Mexico (SCT); Brazil (ANATEL); Argentina (CNC); South Africa (ICASA)
Scan
Scanner advanced features
OCR (Optical Character Recognition); Smart Taks shortcuts: 1-click customizable scan to cloud destinations, email, and print, create editable, searchable documents by scanning from phone or printer; Smart Tasks destinations: Dropbox, Google Drive, One drive, email recipients, print
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 15 ipm (200 ppi, b&w); Up to 8 ipm (200 ppi, color)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Duplex ADF scanning
Yes
Maximum flatbed scan size (metric)
215.9 x 297 mm
Minimum ADF scan size (metric)
127 x 127 mm
Maximum ADF scan size (metric)
215 x 355 mm
Twain version
Version 2.2
Security
Security management
SSL/TLS (HTTPS); IPP over TLS; WPA2-Enterprise wired; 802.1x wireless authentication (EAP-TLS, LEAP, and PEAP); Pre-Shared Key Authentication for Wireless (PSK); Firewall; Certificates Configuration, Control panel lock; Password protect EWS; Unused protocol and service disablement; Syslog; Signed firmware; Administrator settings; Secure boot with self healing; Automatic firmware update; Secure WiFi direct; Encrypted customer data; Secure Erase; Secure Digital send; Certificates Management;
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
OS X v10.11 El Capitan; macOS Sierra v10.12 (previously OS X); macOS High Sierra v10.13 macOS Mojave v10.14; 1.5 GB HD; Internet; USB
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 10, 8, 7: 32-bit  or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Linux (For more information, see http://hplipopensource.com/hplip-web/index.html)
Operating system (supported note)
Windows XP and Windows Vista not supported
One-year limited hardware warranty; 24-hour, 7 days a week Web support; business hour phone support within warranty period
