    Fix Windows 10 Update Issues
HP Notebook - 15-dw0033nr Product Specifications
6KD61UA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
Intel® UHD Graphics 620
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 AC smart pin
32.68 x 22.55 x 1.79 cm
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 9 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Stereo speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Support Assistant; HP BIOS Protection
Pre-installed software
Netflix
