    Fix Windows 10 Update Issues
HP Notebook - 14s-dk0004ax Product Specifications
6MZ24PA
AMD Ryzen™ 3 3200U with Radeon™ Vega 3 Graphics (2.6 GHz base clock, up to 3.5 GHz max boost clock, 5 MB cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
1 TB 5400 rpm SATA
14" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 RJ-45; 1 USB 3.1 Gen 1 Type-C™ (Data transfer only, data 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 headphone/microphone combo; 1 AC smart pin
32.4 x 22.59 x 1.99 cm
Starting at 1.47 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion prismatic and polymer
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP JumpStart; HP Support Assistant
