    Fix HP Printer issue on macOS
HP LaserJet Managed MFP E67650, E67660 - Printer specifications
The following specifications are correct at the time of publication, but they are subject to change. For current information, see www.hp.com/support/colorljE67650mfp or www.hp.com/support/colorljE67660mfp.
Technical specifications
Paper handling specifications
Paper handling features
Model E67650dh, E67660z
(Product # 3GY31A, 3GY32A)
Tray 1 (100-sheet capacity)
Tray 2 (550-sheet capacity)
1 x 550-sheet paper feeder
These models accepts up to two optional 1 x 550-sheet feeders.
Optional
1 x 550-sheet paper feeder with stand
Optional
3 x 550-sheet paper feeder with stand
Optional
High-capacity input tray with stand
Optional
900-sheet 3-bin stapling mailbox
E67660z
Automatic duplex printing
Connectivity specifications
Connectivity features
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Easy-access USB port for printing without a computer and upgrading the firmware
Hardware Integration Pocket for connecting accessory and third-party devices
HP Internal USB Ports
Optional
HP Jetdirect 2900nw Print Server accessory for wireless connectivity
Optional
HP Jetdirect 3100w BLE/NFC/Wireless Accessory for printing from mobile devices
Connected via the Hardware Integration Pocket or the rear host USB port. The HP Jetdirect 3100w BLE/NFC/Wireless Accessory requires the HP Internal USB ports accessory.
Optional
Print specifications
Print features
Prints 50 pages per minute (ppm) on letter and 47 ppm on A4-size paper
E67650dh
Prints 60 pages per minute (ppm) on letter and 56 ppm on A4-size paper
E67660z
Easy-access USB printing (no computer required)
Store jobs in the printer memory to print later or print privately
Copy and Scan specifications
Copy and Scan features
Copy and scan speeds are subject to change. For the most current information go to www.hp.com/support/colorljE67650mfp or www.hp.com/support/colorljE67660mfp.
Copies 50 pages per minute (ppm) on letter and 47 ppm on A4-size paper
E67650dh
Copies 60 pages per minute (ppm) on letter and 56 ppm on A4-size paper
E67660z
Scans at 75 images per minute (ipm) (simplex and duplex)
Scans at 90 ipm (simplex)
E67660z
Scans at 180 ipm (duplex)
E67660z
150-page document feeder with dual-head scanning for single-pass duplex copying and scanning
HP EveryPage Technologies including ultrasonic multi-feed detection
E67660z
Embedded optical character recognition (OCR) provides the ability to convert printed pages into text that can be edited or searched using a computer
E67660z
SMART Label feature provides paper-edge detection for automatic page cropping
E67660z
Automatic page orientation for pages that have at least 100 characters of text
E67660z
Automatic tone adjustment sets contrast, brightness, and background removal for each page
E67660z
Digital Send specifications
Digital Send features
Send documents to email, USB, and shared folders on a network
Send documents to SharePoint®
E67660z
Memory Specifications
Memory features
2 GB base memory
The base memory is expandable to 2.5 GB by adding a DIMM memory module.
E67650dh
2.5 GB base memory
The base memory is expandable to 3 GB by adding a DIMM memory module.
E67660z
Other specifications
Other features
Color touchscreen control panel
Physical keyboard
E67660z
Mass storage: 320 GB Hard Disk Drive
Security: HP Trusted Platform Module for encrypting all data that passes through the printer
Optional
Fax
Optional (E67660z)
Optional (E67650dh)
Supported operating systems
Linux: For information and print drivers for Linux, go to www.hp.com/go/linuxprinting.
UNIX: For information and print drivers for UNIX®, go to www.hp.com/go/unixmodelscripts.
The following information applies to the printer-specific Windows HP PCL 6 print drivers, HP print drivers for macOS, and to the software installer.
Windows: Download HP Easy Start from 123.hp.com/LaserJet to install the HP print driver. Or, go to the printer-support website for this printer: www.hp.com/support/colorljE67650mfp or www.hp.com/support/colorljE67660mfp to download the print driver or the software installer to install the HP print driver.
macOS: Mac computers are supported with this printer. Download HP Easy Start either from 123.hp.com/LaserJet or from the Printer Support page, and then use HP Easy Start to install the HP print driver.
  1. Follow the steps provided to download the printer software.
Supported operating systems and print drivers
Print driver (for Windows, or the installer on the web for macOS)
Windows 7, 32-bit and 64-bit
The “HP PCL 6” printer-specific print driver is installed for this operating system as part of the software installation.
Windows 8, 32-bit and 64-bit
Windows 8.1, 32-bit and 64-bit
The “HP PCL-6” V4 printer-specific print driver is installed for this operating system as part of the software installation.
Windows 10, 32-bit and 64-bit
Windows Server 2008 R2, SP 1, 64-bit
The PCL 6 printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2012, 64-bit
Windows Server 2012 R2, 64-bit
Windows Server 2016, 64-bit
macOS 10.12 Sierra, macOS 10.13 High Sierra
Download HP Easy Start from 123.hp.com/LaserJet, and then use it to install the print driver.
Supported operating systems can change.
For a current list of supported operating systems, go to www.hp.com/support/colorljE67650mfp or www.hp.com/support/colorljE67660mfp for HP's all-inclusive help for the printer.
For details on client and server operating systems and for HP UPD driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click the links.
Minimum system requirements
Windows
macOS
  • Internet connection
  • Dedicated USB 1.1 or 2.0 connection or a network connection
  • 2 GB of available hard-disk space
  • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
  • 1.5 GB of available hard-disk space
The Windows software installer installs the HP Smart Device Agent Base service. The file size is approximately 100 kb. Its only function is to check for printers connected via USB hourly. No data is collected. If a USB printer is found, it then tries to locate a JetAdvantage Management Connector (JAMc) instance on the network. If a JAMc is found, the HP Smart Device Agent Base is securely upgraded to a full Smart Device Agent from JAMc, which will then allow printed pages to be accounted for in a Managed Print Services (MPS) account. The driver-only web packs downloaded from hp.com for the printer and installed through the Add Printer wizard do not install this service.
To uninstall the service, open the Control Panel, select Programs or Programs and Features, and then select Add/Remove Programs or Uninstall a Program to remove the service. The file name is HPSmartDeviceAgentBase.
Printer dimensions
Dimensions for E67650dh
Dimension
Printer fully closed
Printer fully opened
Height
658 mm
910 mm
Depth
460 mm
770 mm
Width
510 mm
963 mm
28 kg
Dimensions for E67660z
Dimension
Height
820 mm
1079 mm
Depth
657 mm
967 mm
Width
657 mm
992 mm
36.6 kg
Dimensions for the 1 x 550-sheet paper feeder
Dimension
Measurement
Height
130 mm
Depth
Tray closed: 458 mm
Tray opened: 770 mm
Width
Door closed: 510 mm
Door opened: 510 mm
6.3 kg
Dimensions for the 1 x 550-sheet paper feeder with stand
Dimension
Measurement
Height
450 mm
Depth
Tray closed: 657 mm
Tray opened: 948 mm
Width
Door closed: 510 mm
Door opened: 992 mm
18.6 kg
Dimensions for the 3 x 550-sheet paper feeder with stand
Dimension
Measurement
Height
450 mm
Depth
Tray closed: 657 mm
Tray opened: 984 mm
Width
Door closed: 657 mm
Door opened: 992 mm
22.7 kg
Dimensions for the high-capacity input (HCI) tray with stand
Dimension
Measurement
Height
450 mm
Depth
Tray closed: 657 mm
Tray opened: 967 mm
Width
Door closed: 657 mm
Door opened: 992 mm
25.2 kg
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1
Printing
Ready
Sleep
Off
780 W
45 W
0.8 W
Less than 0.1 W
1Values subject to change.
Electrical specifications
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the printer warranty.
Power and rated current specifications
Specification
110-volt models
220-volt models
Power requirements1
100 to 127 volts (± 10%)
50/60 Hz (± 3 Hz)
220 to 240 volts (± 10%)
50/60 Hz (± 3 Hz)
Rated current
12 amps
6 amps
1Power reported is highest value measured for all printer models using standard voltages.
Acoustic emissions
Ensure the printer is installed in an area where the printer sound level will not disturb workers.
Acoustic declared values
Printer status
Sound power level
Sound pressure level
Ready
LwAD = < 4.6 Bels (A)
LpAm = 32 dB(A)
Printing
LwAD = < 6.8 Bels (A)
LpAm = 53 dB(A)
Copy
LwAD = < 7.2 Bels (A)
LpAm = 57 dB(A)
Scan
LpAm = 57 dB(A)
Operating-environment range
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17° to 25°C
15° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
