    Fix Windows 10 Update Issues
HP LaserJet Managed E60155, E60165, E60175 - Printer views
Printer front view
    Figure : Printer front view
  1. Color touchscreen display control panel
  2. Output bin
  3. Cartridge door release button (access to the toner cartridge)
  4. On/off button
  5. Cartridge door and Tray 1
  6. Tray 2
  7. Easy-access USB printing port
  8. Hardware integration pocket (for connecting accessories and third-party devices)
Printer back view
The printer is shown without a finishing accessory attached.
    Figure : Printer rear view
  1. Slot for a cable-type security lock
  2. Formatter plate (contains the interface ports)
  3. Power connection
  4. Serial number and product number label
  5. Rear door (for jam access)
Interface ports
    Figure : Interface ports
  1. Host USB port for connecting external USB devices (this port might be covered)
  2. Local area network (LAN) Ethernet (RJ-45) network port
  3. Hi-Speed USB 2.0 printing portFor easy-access USB printing, use the USB port near the control panel.
Control-panel view
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by selecting the Home button.
For more information about the printer-control-panel features, go to www.hp.com/support/ljE60155, www.hp.com/support/ljE60165, or www.hp.com/support/ljE60175, select Manuals, and then select General reference.
The features that appear on the Home screen can vary, depending on the printer configuration.
    Figure : Printer control panel
  1. Reset button
  2. Sign In or Sign Out button
  3. Information button
  4. Help button
  5. Current time
  6. Applications area
  7. Home-screen page indicator
  8. Home button
How to use the touchscreen control panel
Use the following actions to use the printer touchscreen control panel.
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
