    Fix Windows 10 Update Issues
HP Notebook - 17-by1033dx Product Specifications
6HS48UA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
  • 1 TB 5400 rpm SATA
  • 128 GB M.2 SSD
Optical drive
DVD-Writer
17.3" diagonal HD+ SVA BrightView WLED-backlit (1600 x 900)
Pointing device
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
41.48 x 27.22 x 2.45 cm
2.45 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours
Video Playback Battery life
Up to 8 hours and 15 minutes
HP Webcam with integrated digital microphone
Stereo speakers
HP Audio Switch; HP Games by WildTangent; HP JumpStart; HP Support Assistant; HP Connection Optimizer
Pre-installed software
Netflix
