    Fix HP Printer issue on macOS
Omen X 25f 240Hz Gaming Display Product Specifications
Panel
4WH47AA
Display panel type
TN with LED backlight
24.5"
Panel active area (W x H)
54.3 x 30.2 cm
Resolution
FHD (1920 x 1080 @ 60 Hz)
Aspect ratio
16:9
Viewing angle (typical)
160° vertical; 170° horizontal
Brightness (typical)
400 cd/m²
Contrast ratio (typical)
1000:1 static; 12000000:1 dynamic
Response times
3 ms on/off; 1 ms (with overdrive)
Pixel pitch
0.283 mm
Display features
Anti-glare; On-screen controls; Plug and Play; User controls; User programmable
Onscreen controls
User controls
Back; Color control; Down; Exit; Gaming; Image control; Information; Input control; Management; Menu; Minus; OK; Plus; Power
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 640 x 480; 720 x 480; 800 x 600
Video/other inputs/cables
Ports
3 USB 3.0 (1 upstream, 2 downstream, power delivery up to 4.5 W)
Display Input Type
1 DisplayPort™ 1.2 in (with HDCP support); 2 HDMI 2.0 (with HDCP support)
Ergonomics
Tilt and swivel angle
Tilt: -5 to +23°
VESA mount
VESA mount compatible (mounting plate ships in the box)
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
65 W (maximum), 30 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
55.75 x 27.25 x 48.96 cm
Dimensions (W x D x H)
55.75 x 33.06 x 9.87 cm
21.95 x 13.02 x 3.89 in
Product dimensions with stand (W x D x H)
21.95 x 10.73 x 19.28 in
6.16 kg
What's in the box
What's in the box
AC power cord; DisplayPort™ cable; USB cable
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% RH
Environmental
Arsenic-free display glass; Low halogen; Mercury-free display backlights
Certifications and compliances
Australian-New Zealand MEPS; BSMI; CB; CCC; CE; CECP; CSA; EAC; FCC; ICES; ISO 9241-307; KC/KCC; NOM; PSB; SEPA; TUV-S; UL; VCCI; Vietnam MEPS; WEEE; ISC; Low blue light
