    Fix Windows 10 Update Issues
HP PrinterOn Enterprise - Does PrinterOn email printing honor the Microsoft Windows driver settings?
When submitting a print document through the PrinterOn Enterprise solution, the configurations that are defined within the printer on the PrinterOn Configuration Manager and the particular printer takes top priority. It is possible to update the PrintWhere plugin, however as a clean up task the PrinterOn solution refreshes the plugin with the information that is defined on the printer from the PrinterOn Configuration Manager.
Applies to PrinterOn Enterprise 3.x and later.
