    Fix Windows 10 Update Issues
HP LaserJet Managed MFP E72425, E72430, E77422, E77428 - Load and print labels
To print on sheets of labels, use only Tray 1 (multipurpose tray). Tray 2, Tray 3 and the optional 2 x 520-sheet trays do not support labels.
Manually feed labels
Use the manual feed mode for Tray 1 (multipurpose tray) to print sheets of labels.
  1. From the software program, select the Print option.
  2. Select the printer from the list of printers, and then click the Properties or Preferences button to open the print driver.
    The name of the button varies for different software programs.
    To access these features from a Windows 8 or 8.1 Start screen, select Devices, select Print, and then select the printer.
  3. Click the Paper/Quality tab.
  4. In the Paper size drop-down list, select the correct size for the sheets of labels.
  5. In the Paper type drop-down list, select Labels.
  6. In the Paper source drop-down list, select Manual feed.
  7. Click the OK button to close the Document Properties dialog box.
  8. In the Print dialog box, click the Print button to print the job.
Label orientation
Labels need to be loaded in a specific manner in order to print correctly.
Tray
How to load labels
Tray 1
Face-down
Bottom edge leading into the printer
Tray 2 or 3
Face-up
Top edge at the left side of the tray
