HP PrinterOn Enterprise - How to disable a specific print submission method?
For PrinterOn Enterprise please follow the steps below.
  1. Login to the PrinterOn Configuration Manager.
  2. Navigate to “Printers”.
  3. Click on the ‘+’ to expand the desired printer and click on “Configure”.
  4. Under workflows uncheck the desired submission method.
    PrinterOn Enterprise workflow options
For PrinterOn Public please follow the steps below.
  1. Login to the PrinterOn, click here
  2. Navigate to “Printers”. Printer icon
  3. Click on "Required Settings" for the desired printer.
  4. Scroll down and under "Using your printer with Web, PrintWhere and Email Printing" uncheck the desired submission method you wish to disable.
    PrinterOn Public printing settings
Applies to PrinterOn Public and PrinterOn Enterprise 3.x and later.
