    Fix Windows 10 Update Issues
    Are you working from home?
HP Spectre Folio - 13-ak0000nf Product Specifications
5ML06EA
Intel® Core™ i7-8500Y (1.5 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics 615
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass 4™ (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB Type-C™ 3.1 Gen 1 (Data up to 5 Gb/s, Power Delivery, DP 1.2, HP Sleep and Charge); 1 headphone/microphone combo
32.01 x 23.45 x 1.54 cm
1.47 kg
65 W AC power adapter
6-cell, 54.28 Wh Li-ion polymer
Battery life mixed usage
Up to 19 hours
Video Playback Battery life
Up to 21 hours and 15 minutes
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP Connection Optimizer; HP JumpStart
Pre-installed software
Netflix
