    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-da0338ur Product Specifications
5GU73EA
Intel® Core™ i3-7020U (2.3 GHz, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
NVIDIA® GeForce® MX110 (2 GB DDR3 dedicated)
500 GB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
2.04 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
Up to 11 hours and 15 minutes
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS 1.2
