HP Pavilion - 14-ce0019tu Product Specifications
4ME99PA
Intel® Core™ i3-8130U (2.2 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 620
1 TB 5400 rpm SATA
14" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® Wireless-AC 3168 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only)
32.68 x 22.17 x 1.79 cm
Starting at 1.59 kg
45 W Smart AC adapter
3-cell, 41 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
