HP Spectre x360 - 13-ap0014tu Product Specifications
5KF54PA
Intel® Core™ i7 8565U (1.8 GHz base frequency(2b), up to 4.6 GHz with Intel® Turbo Boost Technology(2g), 8 MB cache, 4 cores)
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
1 microSD media card reader
2x USB Type-C™ 3.1 Gen 2 (Thunderbolt™ 3, DP 1.2, PD 3.0, Data transfer, HP Sleep and Charge ); 1x USB 3.1 Gen2 Type-A™ (HP Sleep and Charge); 1 headphone/microphone combo
30.88 x 21.79 x 1.45 cm
Starting at 1.32 kg
65 W AC power adapter
4-cell, 61 Wh Li-ion polymer
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
