External power cables: One
PCIe
2x4 (8pin) & One
PCIe
2x3 (6pin)
DirectX: DX 12
PCIe x16 Gen3
No integrated graphics
The Hamburg motherboard does not support integrated graphics.
Sound/Audio
Integrated audio
Audio Codec: ALC1150
Audio jack presence detection
An internal speaker is not included with integrated audio. External speakers or headphones are required to hear sound.
Integrated audio is not available if a sound card is installed.
Networking
Integrated Bluetooth 4.2 and Wireless LAN 802.11a/b/g/n/ac featuring Dual-band (2.4 GHz and 5.0 GHz) 2 x 2 technology
Interface: M.2
Transmission standards: 802.11 a/b/g/n/ac
Dual band: 2.4 GHz and 5.0 GHz
LAN: 1000BASE-T
Technology: Realtek RTL8161GSH
Data transfer speeds: up to 10/100/1000 Mb/s
Transmission standards: 1000BASE-T Ethernet
Hard drives
512 GB PCIe NVMe TLC M.2 Solid State
Interface: M.2
Type: TLC Solid State
3 TB
Interface: SATA
Rotational speed: 7200 rpm
CD/DVD disc drive
No included disc drive
There is no disc drive included with this model.
Memory card reader
3-in-1 media carder
Figure : Media card reader
Supports the following cards:
Secure Digital (SD)
Secure Digital High Capacity (SDHC)
SDXC
Computer case
Chassis
Your configuration might vary depending on your model.
Figure : Typhon front and right side
Graphics card fan vent
Lighting (Red)
Side I/O panel
Four drive bays with removable trays
Optical drive tray
PSU area/removable panel
Height: 51.51 cm (20.28 in)
Width: 50.42 cm (19.85 in)
Depth: 40.59 cm (15.98 in)
28.20 kg (62.17 lbs) - without packaging
Power supply
Internal 1300 W PSU
1300 W Gold efficiency internal power supply
I/O ports
Side I/O ports
The configuration might vary slightly depending on your model.
Microphone: 1
Headphone/Microphone: 1
USB 3.0: 1
USB 3.0 fast charging: 1
USB 3.0-Type C: 2
Back I/O ports
The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
Figure : Hamburg back I/O panel
Optical SPDIF connector
USB 3.1: 1
USB 3.1: 1
USB 3.1: 6
LAN (Ethernet)
Headphone Jack
Keyboard, mouse and input devices
No included keyboard
This model does not come with a keyboard.
No included mouse
This model does not come with a mouse.
Titles that shipped with PC
HP provides basic support for software that comes with the computer. For in-depth feature assistance, refer to the help section in the software or on the software vendor's Web site.
Software Category
Software Title
Recovery Manager: Program Reinstallation
Operating System
Microsoft Windows 10 Home (64-bit)
No
Entertainment, Music & Games
DTS Headphone:X
HP Audio Switch
Netflix
No
Yes
No
Productivity
Dropbox
HP Jumpstart
HP Jumpstart Apps
No
No
No
Imaging, Photography, Video & Film
HP ePrint
OMEN Command Center
No
Yes
Security
McAfee LiveSafe (12-month subscription)
No
Support
HP Documentation
HP PC Hardware Diagnostics UEFI
HP Support Assistant
Yes
Yes
Yes
Recovery
HP Recovery Manager
No
Browser
Microsoft Edge
No
This support document provides specifications and component images that reflect the original design intention for all PCs of this model. Under certain circumstances, a factory or service provider may install a component that meets or exceeds the listed specification and/or appears different than the image shown.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
