    Fix Windows 10 Update Issues
    Are you working from home?
Product Specifications for the HP DeskJet Ink Advantage 2134 All-in-One Printer (4HM22A)
Product naming
Model name
4HM22A
What's included and accessories
What's in the box
HP DeskJet Ink Advantage 2134 All-in-One Printer; HP 664 Setup Black Original Ink Advantage Cartridge (~120 pages); HP 664 Setup Tri-color Original Ink Advantage Cartridge (~100 pages); Setup Poster; Power cord; [For ink volume and page yield information, visit hp.com/go/learnaboutsupplies.]
Accessories
None
Connectivity
Ports
1 Hi-Speed USB 2.0
Wireless capability
No
Storage device and direct print support
Storage devices not supported
Copy
Copier settings
Auto-enlarge
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy resolution
Up to 600 x 300 dpi
Environmental
Acoustic power emissions
6.2 B(A)
Acoustic pressure emissions
48 dB(A)
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30ºC
Recommended operating temperature range (Fahrenheit)
59 to 86ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Environmental specifications
None
Memory
Memory
Integrated memory
Maximum Memory
Integrated memory
Mobile printing capability
Mobile printing services
Mobile Print Capability not supported
Paper handling
Input capacity
Up to 60 sheets
Standard input capacity (cards)
Up to 20 cards
Standard input capacity (envelopes)
Up to 5
Standard input capacity (transparencies)
Not Applicable
Standard input capacity (secondary tray)
Not Applicable
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
89 x 127 to 215 x 279 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain paper, Photo paper, Brochure paper
Media weight supported (metric)
A4: 60 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP cards: up to 200 g/m²; HP 10 x 15 cm photo paper: up to 300 g/m²
Media weight supported (U.S. standard)
20 lb
Borderless printing
No
Paper handling - ADF
Automatic document feeder capacity
Not Applicable
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Not Applicable
Physical dimensions
Maximum dimensions (W x D x H, metric)
424.97 x 519.36 x 248.77 mm (with Input & Output Tray/Extension extended)
Maximum dimensions (W x D x H, U.S. standard)
16.73 x 20.44 x 9.79 in
Weight (metric)
3.42 kg
Weight (U.S. standard)
7.55 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Internal
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz). Input voltage: 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz) (China & India)
Power consumption
10 watts maximum, 10 watts (Active), 0.1 watts (Off), 1.9 watts (Standby), 0.9 watt (Sleep)
Print cartridges
Number of print cartridges
2 (1 black, 1 Tri-color)
Replacement cartridges
F6V29AL - HP 664 Black Original Ink Advantage Cartridge (~120 pages); F6V28AL - HP 664 Tri-color Original Ink Advantage Cartridge (~100 pages); F6V31AL - HP 664XL High Yield Black Original Ink Advantage Cartridge (~480 pages); F6V30AL - HP 664XL High Yield Tri-color Original Ink Advantage Cartridge (~330 pages)
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed (black, draft, Letter)
Up to 20 ppm
Print speed (color, draft, Letter)
Up to 16 ppm
Print speed black (ISO)
Up to 7.5 ppm
Print speed color (ISO)
Up to 5.5 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi
Maximum print area (metric)
215 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Printer smart software features
Manual Duplex
Regulatory specifications
Regulatory model number
SNPRH-1504 -01
Energy efficiency
ENERGY STAR® qualified
Safety
IEC 60950-1: 2005 (2nd ed.)/EN 60950-1: 2006; Compliance CE Marking to LVD 2006/95/EC; EC recommendation 1999/519/EC; EN 62479: 2010 (Europe), NOM 019-SCFI-1993 (Mexico), CCC Certified GB4943.1-2011 (CCC S&E -China); CNS 14336: 1999 & CNS13438 (BSMI-Taiwan); EAC (Russia), Mexico NOM-1-NYCE.
Electromagnetic compatibility
CISPR 22: 2008/EN 55022: 2010 Class B, CISPR24: 2010/EN 55024: 2010, EN 61000-3-2: 2006+ A1:2009+ A2:2009, EN 61000-3-3: 2008, FCC CFR 47 Part 15 Class B; ICES-003, Issue 4 Class B; GB4943.1-2011 (CCC S&E -China), CNS 14336: 1999 & CNS13438 (BSMI-Taiwan), VCCI-2 (Japan), EAC (Russia); KCC (Korea).
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
Not Applicable
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 1.9
System requirements
Minimum system requirements for Windows
Windows 10, 8.1, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft® Internet Explorer. Windows Vista: 800 MHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel® Pentium® II, Celeron® or 233 MHz compatible processor ,850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
OS X v10.8 Mountain Lion, OS X v10.9 Mavericks, OS X v10.10 Yosemite; 1 GB HD; Internet; USB
Recommended Macintosh system requirements
With services, software, solutions and support from HP Total Care, you can use, protect and enjoy your HP Technology. Comes with one-year technical phone support; One-year limited hardware warranty; For more info please visit us at http://support.hp.com
