    Fix Windows 10 Update Issues
HP Inkjet Supplies - Change to Printhead Packaging
HP recently changed the packaging for HP 70, 72, 73, 88, 91, 706, 744, 761, 762, 771, 773, 789, 792, 831, 940 and 941 Printheads.
New packaging: printheads are packaged in a plastic shell with a foil lid.
Old packaging: printheads are packaged in a plastic tray inside a foil pouch.
The old packaging may still be available in stores for some time. Product function is not affected by this change. The printheads in the new packaging are genuine HP products.
As indicated on the foil pouch, printheads should always be shaken 6 times before installation.
Printhead label with shake instruction
