Document ID: c06114651
Version: 1
Advisory: HP ZBook x2 Detachable Workstation - Rapid Pen Strokes Result In Lag Or Shortened Lines
Release date : 15-Aug-2018
Last updated : 16-Aug-2018
DESCRIPTION
When HP Create Control Panel is installed, rapid back and forth pen strokes may result in lag and result lines on display might be shorter than strokes.
This issue occurs when:
  • HP Create Control Panel is installed
  • A pen is used to make rapid back and forth strokes (zigzag pattern)
SCOPE
Systems:
  • HP ZBook x2 G4 Detachable Workstation
Operating Systems:
  • Microsoft Windows 10 RS3 (Version 1709)
RESOLUTION
Update the HP Create Control Panel to the following version or later:
Version
Softpaq
6.3.30rc8 Rev.A
Hardware platforms affected : HP ZBook x2 G4 Detachable Workstation
Support Communication Cross Reference ID : IA06114651
