    Fix Windows 10 Update Issues
HP Notebook - 15-da0009cy Product Specifications
4SR03UA
Intel® Core™ i3-8130U (2.2 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal HD SVA WLED-backlit touch screen (1366 x 768)
Pointing device
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers
