    Fix Windows 10 Update Issues
    Are you working from home?
OMEN by HP - 17-an146nb Product Specifications
4CK10EA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1070 (8 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
43.9 cm (17.3") diagonal FHD 120 Hz IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size 2-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
1 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 Mini DisplayPort™; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone-in
42.3 x 30.4 x 3.3 cm
3.78 kg
230 W AC power adapter
8-cell, 86 Wh Li-ion
Battery life mixed usage
Up to 14 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
OMEN Command Center; HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
