HP Elite x2 1013 G3 Specifications
Product image
Figure : HP Elite x2 1013 G3 Tablet
Operating systems
Feature
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic only)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
Windows 10 Pro 64
Preinstalled (Others)
FreeDOS 1.2
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, and/or software to take full advantage of Windows functionality.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i7-8650U vPro processor
1.9 GHz base frequency
Up to 4.2 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Intel UHD Graphics 620
Intel Core i5-8550U SIPP processor
1.8 GHz base frequency
Up to 4 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Intel Core i5-8350U VPro processor
1.7 GHz base frequency
Up to 3.6 GHz with Intel Turbo Boost Technology
6 MB cache, 4 cores
Intel Core i5-8250U
1.6 GHz base frequency
Up to 3.4 GHz with Intel Turbo Boost Technology
6 MB cache, 4 cores
Integrated with procesor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors runs at lower speeds in battery optimization mode.
Intel Turbo Boost performance varies depending on hardware, software, and overall system configuration.
Some functionality of vPro, such as Intel Active management technology and Intel Virtualization technology, requires additional 3rd-party software in order to run. Availability of future "virtual appliances" applications for Intel vPro technology is dependent on 3rd-party software providers. Compatibility of this generation of Intel vPro technology-based hardware with future "virtual appliances" is yet to be determined.
Graphics
Feature
Integrated
High-definition (HD) content is required to view high definition images.
Feature
Displays
Touch
33.02 cm (13 in) diagonal 3kx2k IPS LED-backlit touch screen with Corning Gorilla Glass 4, Low Power Ultra Slim bent, 450 cd/m², RGB (3000 x 2000)
HP Sure View Integrated Privacy Screen
33.02 cm (13 in) diagonal FHD IPS eDP LED-backlit touch screen with Corning Gorilla Glass 4, CWLED UWVA 700 cd/m², RGB (1920 x 1280)
HP Sure View Integrated Privacy screen is optional and must be configured at purchase.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Sold separately or as an optional feature.
Storage
Feature
M.2 Solid State Drive (SSD)
128 GB SATA-3 SS TLC
256 GB PCIe TLC Opal 2
256 GB PCIe NVMe Value
256 GB PCIe Gen3x4 NVMe SS TLC
512 GB PCIe Gen3x4 NVMe SS TLC
1 TB PCIe Gen3x4 NVMe SS TLC
512 GB PCIe Opal 2 TLC
512 GB SATA SS TLC Federal Information Processing Standard (FIPS 140.2 available via CIS only)
For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Feature
Standard
LPDDR3-2133 (transfer rates up to 2133 MT/s)
Soldered down, on-board memory (customer non-accessible)
Dual channel support
Configurations
4 GB LPDDR3-2133 SDRAM
8 GB LPDDR3-2133 SDRAM
16 GB LPDDR3-2133 SDRAM
Maximum
16 GB
Due to the non-industry standard nature of some third-party memory modules, only HP branded memory is recommended to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Audio/multimedia
Feature
Audio
Bang & Olufsen (B&O)
(3) Integrated Multi Array microphones
Dual speakers (front-facing) with discrete amp
HP Noise Cancellation Headphone line-out and microphone-in (combo)
72 dB Audio Level
Camera
Integrated 5 MP (1080p) - front
Integrated 8 MP with flash (1080p) - back
Integrated VGA IR camera with IR LED emitters that meets Microsoft Hello face recognition certification for secure authentication (Internet access required)
Sold separately or as an optional feature. Microsoft Hello requires Windows 10.
Keyboard/pointing device/function keys
Feature
Keyboard
Collaboration travel keyboard
Pointing device
Touchpad
Multi-touch gestures enabled by default
Function keys
Function keys
F1–Display Switching
F2–Sure View (toggle)
F3–Brightness down
F4–Brightness up
F5–Audio mute
F6–Volume down
F7–Volume up
F8–Microphone mute
F9–Backlight toggle
F10–NumLock
F11–Wireless on/off
F12–Calendar
Other keys
Esc key
Delete key
Collaboration keys
Call End
Share/Present
Call Answer
Ports/slots
Feature
Ports
(2) USB 3.1 Type-C with Thunderbolt
(1) USB 3.1 Type-C power port (power delivery, DisplayPort)
(1) Headphone/microphone combo jack
Slots
(1) Nano SIM
Networking/communication
Feature
Wireless LAN
Intel Dual band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi with Bluetooth 4.2 Combo (Intel vPro supported)
Intel Dual band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi with Bluetooth 4.2 Combo (Intel non-vPro supported)
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Wireless WAN
Integrated WWAN options with dual antennas:
HP lt4132 LTE/HSPA+ with GPS Mobile Broadband Module
HP lt4220 LTE/HSPA+ with GPS Mobile Broadband Module
WWAN is an optional feature and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds might vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all regions.
WWAN cards are compatible with a programmable removable eSIM.
Dynamic Regulatory Solution will auto-change AC WLAN to abgn by passive scan when entering Indonesia.
Miracast
Native Miracast support
Standalone GPS
HP Graff GNSS Module
An optional feature and requires factory configuration. GPS and WWAN are mutually exclusive.
Software/security
Feature
BIOS
HP BIOSphere Gen4
HP DriveLock and Automatic DriveLock
BIOS Update via Network
Master Boot Record Security
HP Sure Start Gen 4
Pre-boot Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Communication/connectivity
HP LAN-Wireless Protection
HP Wireless Wakeup
HP Value Add Software
HP Velocity
HP ePrint Driver with JetAdvantage2
HP Hotkey support
HP Recovery Manager—CMIT
HP Jumpstart
HP Support Assistant (requires Windows and Internet access)
HP Noise Cancellation software
HP Sure Click (available on select HP platforms and supports Microsoft Internet Explorer, Google Chrome, and Chromium.)
HP Sure Start Gen4
Microsoft products
Buy Office (sold separately)
Manageability features
HP Driver Packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Config Utility (BCU) (subscription required)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft System Center Configuration Manager (available for download)
Ivanti Management Suite (subscription required)
HP Manageability Integration Kit Gen2 (available for download)
HP Fingerprint Sensor (sold separately or as an optional feature)
Client security software
Microsoft Defender
Opt in and internet connection required for updates.
Trusted Platform Module (TPM) 2.0
Embedded security chip shipped with Windows 10
Common Criteria EAL4+ Certified)
HP Client Security Suite Gen 4
Requires Windows and Intel or AMD 7th or 8th generation processors.
HP Security Manager (HP Credential Manager, HP Password Manager, HP Spare Key)
HP Power On Authentication
HP Device Access Manager
HP Sure Click
HP PhoneWise (available as a free download on the App Store and Google Play)
HP Sure Run
HP Sure Recover
HP Sure View Gen 2
Hardware security
SATA 0, 1 port disablement (via BIOS)
RAID configurations (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
Integrated hood sensor
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Feature
Power supply
HP 65 W External AC power adapter non-PFC USB-C
HP 65 W External AC power adapter nPFC slim USB USB-C
Supports HP fast charging. Availability might vary by country.
Primary battery
HP Long Life, 4-cell, 50 Wh polymer (3250 mAhr/cell)
Battery is internal and not replaceable by customer. Serviceable by warranty.
Battery life
Up to 10 hours 30 minutes
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Battery charge time
50% in 30 minutes
Units enabled with 65 w adapters or higher can support fast charging of the battery from 0-50% in 30 minutes while the system is off.
Power cord
Duckhead power cord length: 1 m (3.28 ft) (AC)
Physical specifications
Feature
Dimensions (W X D X H)
Tablet
30.0 x 0.79 x 23.14 cm (11.81 x 0.31 x 9.11 in)
Tablet and keyboard
30.0 x 1.32 x 23.14 cm (11.81 x 0.52 x 9.11 in)
Tablet
808 g (1.78 lb)
Keyboard
368 g (0.81 lb)
Tablet and keyboard
1.175 kg (2.59 lb)
Weight varies by configuration and components.
