    Fix Windows 10 Update Issues
    Are you working from home?
HP Stream x360 - 11-aa009nx Product Specifications
1TP26EA
Intel® Celeron® N3060 (1.6 GHz base frequency, up to 2.48 GHz burst frequency, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
  • Intel® HD Graphics 400
  • Integrated
32 GB eMMC
29.5 cm (11.6") diagonal HD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.1
30.6 x 20.8 x 1.98 cm
1.35 kg
45 W AC power adapter
Battery life mixed usage
Up to 11 hours and 30 minutes
HP Webcam with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
Office 365 Personal 1-year
