4MC05PA
OMEN by HP - 15-dc0022tx
Intel® Core™ i5-8300H (2.3 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (1 x 16 GB)
1 TB 7200 rpm SATA
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size 4-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
36 x 26.3 x 2.5 cm
Starting at 2.4 kg
150 W AC power adapter
4-cell, 70 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
- ${title}
- ${title}
- ${title}
- ${title}
OMEN by HP - 15-dc0022tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; OMEN Command Center; HP Connection Optimizer
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
