    Are you working from home?
    Fix Windows 10 Update Issues
OMEN by HP - 15-dc0045ur Product Specifications
4RM71EA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1070 (8 GB GDDR5 dedicated)
  • 1 TB 7200 rpm SATA
  • 128 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size 2-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
36 x 26.3 x 2.5 cm
200 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 6 hours and 15 minutes
Video Playback Battery life
Up to 4 hours and 45 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
OMEN Command Center; HP Audio Switch; HP CoolSense; HP JumpStart
