    Fix Windows 10 Update Issues
    Are you working from home?
OMEN by HP - 15-dc0020ur Product Specifications
4HC76EA
Intel® Core™ i5-8300H (2.3 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size 2-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
36 x 26.3 x 2.5 cm
2.38 kg
135 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 6 hours and 15 minutes
Video Playback Battery life
Up to 4 hours and 45 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
FreeDOS 1.2
