    Fix HP Printer issue on macOS
HP ProOne 600 G4 21.5-in AiO Business PC (Touch & Non-Touch) Specifications
Product image
Figure : HP ProOne 600 G4 21.5-in All-in-One Business PC (Touch & Non-Touch)
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Pre-installed (other)
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-8700 processor
65 W
3.2 GHz (up to 4.6 GHz with Intel Turbo Boost technology)
12 MB cache, 6 cores, 12 threads
Intel UHD Graphics 630
Supports Intel vPro Technology and Intel Stable Image Platform Program (SIPP)
Intel Core i7+ 8700 processor available with Intel Optane memory (sold separately)
Intel Core i7-8700T processor
35 W
Up to 4.0 GHz maximum Turbo Frequency (2.4 GHz base frequency)
DDR4 memory up to 2666 MT/s data rate
Intel Core i7+ 8700T processor available with Intel Optane memory (sold separately)
Intel Core i5-8600 processor
65 W
3.1 GHz (up to 4.3 GHz with Intel Turbo Boost technology)
9 MB cache, 6 cores, 6 threads
Intel Core i5+ 8600 processor available with Intel Optane memory (sold separately)
Intel Core i5-8600T processor
35 W
Up to 3.7 GHz maximum Turbo Frequency (2.3 GHz base frequency)
Intel Core i5+ 8600T processor available with Intel Optane memory (sold separately)
Intel Core i5-8500 processor
65 W
3.0 GHz base frequency (up to 4.1 GHz with Intel Turbo Boost technology)
Intel Core i5+ 8500 processor available with Intel Optane memory (sold separately)
Intel Core i5-8500T processor
35 W
Up to 3.5 GHz maximum Turbo Frequency (2.1 GHz base frequency)
Intel Core i5+ 8500T processor available with Intel Optane memory (sold separately)
Intel Core i3-8300 processor
62 W
3.7 GHz base frequency
8 MB cache, 4 cores, 4 threads
DDR4 memory up to 2400 MT/s data rate
Intel Core i3-8300T processor
35 W
3.2 GHz base frequency
Intel Core i3-8100 processor
65 W
3.6 GHz base frequency
6 MB cache, 4 cores, 4 threads
Intel Core i3-8100T processor
35 W
3.1 GHz base frequency
Intel Pentium Gold G5500 processor
54 W
3.8 GHz base frequency
4 MB cache, 2 cores, 4 threads
Intel Pentium Gold G5500T processor
35 W
Intel Pentium Gold G5400 processor
54 W
Intel UHD Graphics 610
Intel Pentium Gold G5400T processor
35 W
Intel Celeron G4900 processor
54 W
2 MB cache, 2 cores, 2 threads
Intel Celeron G4900T processor
35 W
2.9 GHz base frequency
Intel Q370
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Optane memory system acceleration does not replace or increase the DRAM in the system.
Intel Turbo Boost technology requires a PC with a processor with Intel Turbo Boost capability. Intel Turbo Boost performance varies depending on hardware, software, and overall system configuration.
Some functionality of vPro technology, such as Intel Active management technology and Intel Virtualization technology, requires additional 3rd-party software in order to run. Availability of future "virtual appliances" applications for Intel vPro technology is dependent on 3rd-party software providers. Compatibility of this generation of Intel vPro technology-based hardware with future "virtual appliances" is yet to be determined.
S-Processor 6+2 DDR4 2666 MT/s 2 DPC UDIMM is supported when channel is populated with the same UDIMM part number.
Memory
Specification
DDR4-2666
Maximum: 32 GB
Number of slots: (2) SODIMM (slots are customer accessible/upgradeable)
Up to 2666 MT/s
Configurations
4 GB total system memory (4 GB x 1)
8 GB total system memory (4 GB x 2)
8 GB total system memory (8 GB x 1)
16 GB total system memory (8 GB x 2)
16 GB total system memory (16 GB x 1)
32 GB total system memory (16 GB x 2)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2666 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Graphics
Specification
Intel HD Graphics (integrated)
Intel Core i7 processor
Intel Core i5 processor
Intel Core i3 processor
Intel Pentium Gold G5600
Intel Celeron G4900
Discrete graphics (optional)
AMD Radeon 530 with 2 GB GDDR5
Adapters
HP DisplayPort to DVI-D Adapter
HP DisplayPort to HDMI True 4K Adapter
HP DisplayPort to VGA Adapter
HP USB-C to USB 3.0 Adapter
HP USB to Serial Port Adapter
Cables
HP DisplayPort Cable
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, 6.35 cm (2.5 in)
1 TB, 7.2 K rpm, 6.35 cm (2.5 in)
2 TB, 5.4 K rpm, 6.35 cm (2.5 in)
Solid State Hybrid drives (SSHD)
500 GB, 5.4 K rpm, 6.35 cm (2.5 in), 8 GB hybrid
1 TB, 5.4 K rpm, 6.35 cm (2.5 in), 8 GB hybrid
2 TB, 5.4 K rpm, 6.35 cm (2.5 in), 8 GB hybrid
Self-Encrypting drives (SED HDD)
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), SED Opal 2
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), SED FIPS
Solid State Drives (SSD)
256 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
512 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED Opal 2
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED Opal 2
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), SED FIPS
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), SED FIPS
PCIe NVMe TLC SSD drives
128 GB M.2 2280 PCIe NVMe SSD
256 GB M.2 2280 PCIe NVMe SSD
512 GB M.2 2280 PCIe NVMe SSD
128 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe TLC SSD
512 GB M.2 2280 PCIe NVMe TLC SSD
1 TB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe Self Encrypted Opal 2 TLC SSD
512 GB M.2 2280 PCIe NVMe Self Encrypted Opal 2 TLC SSD
Optical disk drives
HP 9.5 mm Slim DVD-ROM Drive3
HP 9.5 mm Slim DVD-Writer Drive4
HP 9.5 mm Slim Blu-ray Writer Drive5
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
3HD-DVD discs cannot be played on this drive. No support for DVD-RAM. Actual speeds might vary. Double Layer discs can store more data than single layer discs. Discs burned with this drive might not be compatible with many existing single-layer DVD drives and players.
4Copyright-protected materials should not be copied.
5With Blu-ray, certain disc, digital connection, compatibility and/or performance issues might arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. In order for some Bluray titles to play, a DVI or HDMI digital connection might be required and your display might require HDCP support. HD-DVD movies cannot be played on this desktop PC.
Keyboards/pointing devices
Specification
Keyboards
HP USB Business Slim Standalone Wired Keyboard
HP USB Business Slim Wired SmartCard CCID Keyboard
HP USB & PS/2 Washable Standalone Wired Keyboard
HP Collaboration Wireless Keyboard
HP USB Collaboration Wired Keyboard
HP USB Conferencing Wired Keyboard
HP USB Wired Keyboard
Standard Wired Keyboard Value
Mice
HP USB Universal Wired Mouse
HP USB Optical Mouse
HP USB Hardened Mouse
HP USB 1000dpi Laser Mouse
HP USB & PS/2 Washable Wired Mouse standalone
Combos
HP Premium Wireless Keyboard and Mouse
HP Business Slim Wireless Keyboard and Mouse
HP USB Keyboard and Mouse Healthcare Edition
HP USB Keyboard and Mouse Wired Value
Availability might vary by country.
Networking/communications
Specification
Ethernet (RJ-45)
Integrated
Intel I219-LM Gigabit Network Connection (standard)
Wireless LAN
Intel 9560 802.11ac 2x2 with Bluetooth M.2 Combo Card vPro
Intel 9560 802.11ac 2x2 with Bluetooth M.2 Combo Card non-vPro
Realtek RTL8821BE 802.11ac 2x2 with Bluetooth M.2 Combo Card
Realtek RTL8723CE 802.11ac 1x1 with Bluetooth M.2 Combo Card
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices
Audio/multimedia
Feature
Audio (integrated)
Conexant CX3601
2 W per channel class D stereo amplifier for the internal speakers only
(1) Side 3.5 mm headset connector supports an OMTP or CTIA style headset and is re-taskable as a Line-in, Line-out, Microphone-in, or Headphone-out port
Ports/slots/bays
Specification
Ports
USB ports
(1) USB Type-C 2.0: (1) side (upgradeable to USB 3.1 Gen 2 port (10 Gbits/s data speed) if configured with additional video port and/or Intel vPro)
(4) USB 3.1 Gen 1: (2) front, 2 (rear)
Video ports
(1) Optional configurable video port (rear)
Choice of DisplayPort 1.2 or HDMI 2.0.
(1) DisplayPort 1.2 (rear)
Audio ports
(1) Headset (front)
(1) Universal Audio Jack with CTIA headset support (side)
Network/communication ports
(1) RJ-45 Ethernet (rear)
(1) Optional Serial RS-232 (rear)
(1) M.2 PCIe x1 2230 (for WLAN)
(2) M.2 PCIe x4 2280/2230 Combo (for storage)
(1) AiO SATA storage connector
Bays
(1) 9.35 cm (2.5 in) internal storage drive
(1) SD card reader
(1) 9 mm Slim optical disc drive (ODD) (non-internal storage bay and must be configured at the time of purchase)
Software/security
Specification
BIOS
HP BIOSphere Gen4
BIOS Update via Network
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module6
Pre-boot Authentication
Communication/connectivity
HP Native Miracast Support
HP Wireless Wakeup (select models only)
HP Value Add Software
HP ePrint Driver with JetAdvantage7
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation Software
HP Velocity
HP Sure Click (available on select HP platforms and supports Microsoft Internet Explorer and Chromium)
HP Sure Start Gen4
Microsoft Products
Buy Office (sold separately)
Manageability
HP System Software Manager (SSM) (available for download)
HP Client Catalog (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Driver Packs (available for download)
HP Manageability Integration Kit Gen2 (available for download)
Ivanti Management Suite (subscription required)
Client Security software
Microsoft Defender
HP WorkWise app (available as a free download on the App Store and Google Play)
HP PhoneWise (might not be available with HP Workwise)
HP Client Security Manager Gen4 (requires Windows and Intel 8th generation processors)
HP Security Manager (including Credential Manager, HP Password Manager, and HP Spare Key)
HP Device Access Manager
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Intrusion sensor (optional)
Common Criteria EAL4+ Certified
Downgradeable to TPM 1.2
Convertible to FIPS 140-2 Certified mode
Intel Identify Protection Technology (IPT)
Chassis cable lock and table lock devices supported
Removable media write/boot control
Power-on password (via BIOS)
Setup password (via BIOS)
SATA port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
6Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
7Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power supply
Specification
External power supplies
90 W EPS, 89% average efficiency at 115 V and 230 Vac
120 W EPS, 89% average efficiency at 115 V and 230 Vac
Rated input current
90 W for less than or equal to 1.2 A
120 W for less than or equal to 2.2 A
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50 - 60 Hz
Operating line frequency
47 - 63 Hz
DC output
+19.5 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 264 Vac with the ground wire disconnected, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 264 Vac with the ground wire intact with normal polarity, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power cord
1.83 m (6.0 ft)
Physical specifications
Specification
System dimensions (including Touch, Non-Touch) (W x D x H)
Without Stand: 489.20 x 51.82 x 321.06 mm (19.26 x 2.04 x 12.64 in)
Cantilever Stand: 489.20 x 149.86 x 364.49 mm (19.26 x 5.9 x 14.35 in)
Height Adjustable Stand: 489.20 x 208.53 x 363.73 mm (19.26 x 8.21 x 14.32 in)
Product weight (Unboxed)
21.5-in Non-Touch
Without Stand: 3.91-4.7 kg (8.61-10.36 lb)
Cantilever Stand: 4.96-5.75 kg (10.93-12.68 lb)
Height Adjustable Stand: 5.78-6.57 kg (12.74-14.48 lb)
21.5-in Touch
Without Stand: 3.92-4.62 kg (8.64-10.19 lb)
Cantilever Stand: 4.97-5.67 kg (10.96-12.5 lb)
Height Adjustable Stand: 5.79-6.49 kg (12.76-14.31 lb)
Environmental
Specification
ENERGY STAR
Certified models available
EPEAT
EPEAT Gold registered where applicable/supported
Registration status varies by country/region.
