HP ProDesk 600 G4 Small Form Factor Business PC Specifications
Product image
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Pre-installed (other)
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-8700 processor
65 W
Up to 4.6 GHz maximum Turbo Frequency (3.2 GHz base frequency)
12 MB cache, 6 cores, 12 threads
Intel UHD Graphics 630
DDR4 memory up to 2666 MT/s data rate
Supports Intel vPro Technology and Intel Stable Image Platform Program (SIPP)
Intel Core i7+ 8700 processor available with Intel Optane memory (sold separately)
Intel Core i5-8600 processor
65 W
Up to 4.3 GHz maximum Turbo Frequency (3.1 GHz base frequency)
9 MB cache, 6 cores, 6 threads
Intel Core i5+ 8600 processor available with Intel Optane memory (sold separately)
Intel Core i5-8500 processor
65 W
Up to 4.1 GHz maximum Turbo Frequency (3.0 GHz base frequency)
Intel Core i5+ 8500 processor available with Intel Optane memory (sold separately)
Intel Core i3-8300 processor
62 W
3.7 GHz base frequency
8 MB cache, 4 cores, 4 threads
DDR4 memory up to 2400 MT/s data rate
Intel Core i3-8100 processor
65 W
3.6 GHz base frequency
6 MB cache, 4 cores, 4 threads
Intel Pentium Gold G5600 processor
54 W
3.9 GHz base frequency
4 MB cache, 2 cores, 4 threads
Intel Pentium Gold G5500 processor
54 W
3.8 GHz base frequency
Intel Pentium Gold G5400 processor
54 W
Intel UHD Graphics 610
Intel Celeron G4900 processor
54 W
2 MB cache, 2 cores, 2 threads
Intel Q370
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Some functionality of vPro technology, such as Intel Active management technology and Intel Virtualization technology, requires additional third-party software in order to run.
Memory
Specification
DDR4-2666
Maximum: 64 GB
Number of slots: (4) DIMM (slots are customer accessible/upgradeable)
Up to 2666 MT/s
Configurations
4 GB total system memory (4 GB x 1)
8 GB total system memory (4 GB x 2)
8 GB total system memory (8 GB x 1)
16 GB total system memory (8 GB x 2)
16 GB total system memory (16 GB x 1)
32 GB total system memory (16 GB x 2)
32 GB total system memory (8 GB x 4)
64 GB total system memory (16 GB x 4)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2666 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Graphics
Specification
Intel HD Graphics (Integrated)
Intel Core i7 processor
Intel Core i5 processor
Intel Core i3 processor
Intel Pentium Gold G5600, G5500
Optional discrete graphics
AMD Radeon R7 430 2 GB, 2 DisplayPort (DP)
AMD Radeon R7 430 2 GB, DP and VGA
Adapters and cables
HP DisplayPort Cable
HP DisplayPort to DVI-D Adapter
HP DisplayPort to HDMI True 4K Adapter
HP DisplayPort to VGA Adapter
HP USB-C to USB 3.0 Adapter
HP USB to Serial Port Adapter
HP Type-C to DisplayPort Adapter
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
2 TB, 5.4 K rpm, 6.35 cm (2.5 in)
500 GB, 7.2 K rpm, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, 8.89 cm (3.5 in)
2 TB, 7.2 K rpm, 8.89 cm (3.5 in)
Solid State Hybrid drives (SSHD)
500 GB, 5.4 K rpm, 6.35 cm (2.5 in), 8 GB hybrid
1 TB, 5.4 K rpm, 6.35 cm (2.5 in), 8 GB hybrid
Self-Encrypting drives (SED HDD)
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), SED Opal 2
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), SED FIPS
Solid State Drives (SSD)
256 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
512 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED Opal 2
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED Opal 2
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), SED FIPS
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), SED FIPS
PCIe NMVe TLC SSD drives
128 GB M.2 2280 PCIe NVMe SSD
256 GB M.2 2280 PCIe NVMe SSD
512 GB M.2 2280 PCIe NVMe SSD
128 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe TLC SSD
512 GB M.2 2280 PCIe NVMe TLC SSD
1 TB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe Self Encrypted Opal 2 TLC SSD
512 GB M.2 2280 PCIe NVMe Self Encrypted Opal 2 TLC SSD
Optical disc drives (optional)
HP 9.5 mm (0.37 in) Slim DVD Writer
HP 9.5 mm (0.37 in) Slim DVD-ROM
HP 9.5 mm (0.37 in) Slim Blu-Ray Writer
Media Card Reader (optional)
SD 4.0 with 5-in-1 interface
Supports SD, SDXC, SDHC, UHS-I, and UHS-II
Card sold separately.
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Keyboards/pointing devices
Specification
Keyboards
HP PS/2 Business Slim Standalone Wired Keyboard
HP USB Business Slim Standalone Wired Keyboard
HP USB Business Slim Wired SmartCard CCID Keyboard
HP USB & PS/2 Washable Standalone Wired Keyboard
HP Premium Standalone Wireless Keyboard
HP Collaboration Wireless Keyboard
HP USB Collaboration Wired Keyboard
HP USB Conferencing Wired Keyboard
HP USB Wired Keyboard
Standalone Wired Keyboard Value
Mice
HP PS/2 Mouse
HP USB Optical Mouse
HP USB Hardened Mouse
HP USB 1000dpi Laser Mouse
HP USB & PS/2 Washable Wired Mouse standalone
HP USB Premium Wired Mouse
Combos
HP Premium Wireless Keyboard and Mouse
HP Premium USB Wired Keyboard and Mouse
HP Business Slim Wireless Keyboard and Mouse
HP USB Keyboard and Mouse Healthcare Edition
HP USB PS/2 Washable Keyboard and Mouse Wired
Availability might vary by country.
Networking/communications
Specification
Ethernet (RJ-45)
Integrated
Intel I219-LM Gigabit Network Connection (standard)
Optional
Intel I210-T1 PCIe x1 Gigabit Network Interface Card
Wireless LAN
Intel 9560 802.11ac 2x2 with Bluetooth M.2 Combo Card vPro
Intel 9560 802.11ac 2x2 with Bluetooth M.2 Combo Card non-vPro
Realtek RTL8821BE 802.11ac 2x2 with Bluetooth M.2 Combo Card
Realtek RTL8723CE 802.11ac 1x1 with Bluetooth M.2 Combo Card
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices
Audio/multimedia
Feature
Audio (integrated)
Conexant CX20632
2 W class D mono amplifier for the internal speaker only
(1) Headset connector supports a CTIA style headset and is retaskable as a Line-in, Line-out, Microphone-in or Headphone-out port (front)
(1) Headphone port (front)
Ports/slots/bays
Specification
Ports
USB ports
(4) USB 2.0: (2) front, (2) rear
(2) USB 3.1 Gen 1 (rear)
(4) USB 3.1 Gen 2: (2) front, (2) rear
(1) USB 3.1 Gen 2 Type-C port (front)
Video ports
(1) Optional configurable video port (rear)
Choice of DisplayPort 1.2, HDMI 2.0, VGA, or USB Type-C with display output.
(2) DisplayPort 1.2 (rear)
Audio ports
(1) Headset (front)
(1) Audio line-in (rear)
(1) Audio line-out (rear)
Network/communication ports
(1) RJ-45 Ethernet (rear)
(2) Optional Serial RS-232 (rear)
Power
(1) Power port
(1) M.2 PCIe x1 2230 (for WLAN)
(1) M.2 PCIe x4 2280/2230 Combo (for storage)
(1) PCI Express x16
(1) PCI Express x4
(3) SATA port
Bays
(2) 6.35 cm (2.5 in) internal storage drive
SFF can be configured with either (1) 3.5 in or (2) 2.5 in internal storage drive (2.5 inch drive needs adapter).
(1) 0.9 cm (0.35 in) Slim optical disc drive (ODD)
(1) 8.89 cm (3.5 in) Internal storage drive
(1) Secure Digital (SD) reader
Software/security
Specification
BIOS
HP BIOSphere Gen4
BIOS Update via Network
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
Communication/connectivity
HP Native Miracast Support
HP Wireless Wakeup (select models only)
HP Value Add Software
HP ePrint Driver with JetAdvantage2
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation Software
HP Velocity
HP Sure Click
HP Sure Start Gen4
Microsoft Products
Buy Office (sold separately)
Manageability
HP System Software Manager (SSM) (available for download)
HP Client Catalog (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Driver Packs (available for download)
HP Manageability Integration Kit Gen2 (available for download)
Ivanti Management Suite (subscription required)
Client Security software
Microsoft Defender
HP WorkWise app (available as a free download on the App Store and Google Play)
HP PhoneWise (might not be available with HP Workwise)
HP Client Security Manager Gen4 (requires Windows and Intel 8th generation processors)
HP Security Manager (including Credential Manager, HP Password Manager, HP Spare Key)
HP Device Access Manager
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Intel Identify Protection Technology (IPT)
Removable media write/boot control
Power-on password (via BIOS)
Setup password (via BIOS)
SATA port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Intrusion Sensor (optional)
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power supply
Specification
80 PLUS Platinum
180 W active PFC
90/92/89% efficient at 20/50/100% load (115 V)
91/93/90% efficient at 20/50/100% load (230 V)
Rated input current
2.3 A
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50 - 60 Hz
Operating line frequency
47 - 63 Hz
DC output
12 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 264 Vac with the ground wire disconnected, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 264 Vac with the ground wire intact with normal polarity, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
50 mm variable speed
Power cord
1.83 m (6.0 ft)
Physical specifications
Specification
Chassis (W x D x H)
93.98 x 269.24 x 297.18 mm (3.7 x 10.6 x 11.7 in)
Packaged (W x D x H)
399.03 x 230.12 x 499.11 mm (15.71 x 9.06 x 19.65 in)
System volume
463 cu in
7.6 L
System weight
4.54 kg (10.01 lb)
Configured with (1) HDD and (1) ODD.
Maximum supported weight (desktop orientation)
35 kg (77.16 lb)
Shipping weight
7.32 kg (16.14 lb)
Environmental
Specification
ENERGY STAR
Certified models available
EPEAT
Registered where applicable/supported
Registration status varies by country/region.
TAA compliance
TAA compliant models available
