    Are you working from home?
    Fix Windows 10 Update Issues
HP 24-f017la All-in-One Desktop PC Product Specifications
SyrahNT 23.8 in All-in-One chassis
Chassis color might vary depending on your model.
Processor
Memory
Video graphics
Sound/Audio
Networking
CD/DVD disc drive
Memory card reader
Computer case
Power supply
I/O ports
Keyboard, mouse and input devices
This support document provides specifications and component images that reflect the original design intention for all PCs of this model. Under certain circumstances, a factory or service provider may install a component that meets or exceeds the listed specification and/or appears different than the image shown.
