    Are you working from home?
    Fix Windows 10 Update Issues
HP Notebook - 15-da0013tx Product Specifications
4JD78PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
  • 1 TB 5400 rpm SATA
  • 128 GB M.2 SSD
15.6" diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect;
