HP Pavilion x360 - 14-cd0007ca Product Specifications
4BP89UA
Intel® Core™ i3-8130U (2.2 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
HP External Portable USB 3.0 Hard Drive
Maximum resolution">1366 x 768
1 USB 3.1 Type-C Gen 1 (Data transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data Transfer Only); 1 HDMI 1.4; 1 headphone/microphone combo
32.35 x 22.42 x 1.97 cm
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY, dual speakers
