HP Notebook - 15-db0007ca Product Specifications
4BQ96UA
AMD Ryzen™ 3 2200U (2.5 GHz base frequency, up to 3.4 GHz burst frequency, 1 MB cache, 2 cores)
Video graphics
  • AMD Radeon™ 530 Graphics (2 GB GDDR5 dedicated)
  • Integrated
HP External Portable USB 3.0 Hard Drive
Maximum resolution">1366 x 768
Pointing device
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers
