HP Pavilion - 14-ce0064st Product Specifications
4AL53UA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
  • 256 GB M.2 SSD
  • [11]
14" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only)
32.68 x 22.55 x 1.79 cm
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY, dual speakers
HP Audio Switch; HP CoolSense; HP ePrint; HP Games by WildTangent; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Pre-installed software
Netflix
