HP 22y 21.5-inch Display - Product Specifications
The HP 22y is a 54.6 cm (21.5 in) Display.
Figure : HP 22y 21.5-inch Display
The HP 22y 21.5-inch Display
1PX47AA, 2YV09AA
Technical specifications
LED feature
Specification
Display size
54.6 cm (21.5 in) diagonal
Display type
TN with LED backlight, anti-glare
Panel active area
47.65 x 26.80 cm (18.76 x 10.55 in)
Brightness
250 nits
Color gamut
72%
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.248 x 0.248 mm
102 PPI
Inputs
1 VGA
1 DVI-D
HDCP support on digital inputs (HDMI)
Viewing angle
Horizontal viewing angle: 90 degrees
Vertical viewing angle: 65 degrees
Scan range
Horizontal: 30-80 kHz
Vertical: 50-60 Hz
Recommended resolution (H x V)
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Static contrast ratio
Up to 600:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
5 ms gray to gray
Power consumption
20 Watts maximum
Tilt
-5 to +15 degrees
Power supply
Internal
Dimensions
W x D x H (unpacked with stand):
50.40 × 17.04 × 38.3 cm (19.84 × 6.71 × 15.08 in)
W x D x H (unpacked without stand):
50.40 × 4.90 × 31.04 cm (19.84 × 1.93 × 12.22 in)
Unpacked with stand: 2.6 kg (5.73 lbs)
Unpacked without stand: 2.46 kg (5.42 lbs)
