The following information provides details about the toner cartridges for the printer, and it includes instructions to replace them.
- ${title}
- ${title}
- ${title}
- ${title}
HP Color LaserJet Managed E55040 - Replace the cartridges
Toner-cartridge information
This printer indicates when the toner-cartridge level is low and very low. The actual toner cartridge life remaining can vary. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
To purchase cartridges or check cartridge compatibility for the printer, go to HP SureSupply at www.hp.com/go/suresupply. Scroll to the bottom of the page and verify that the country/region is correct.
The printer uses four colors and has a different toner cartridge for each color: yellow (Y), magenta (M), cyan (C), and black (K). The toner cartridges are inside the front door.
note:High-yield toner cartridges contain more toner than standard cartridges for increased page yield. For more information, go to www.hp.com/go/learnaboutsupplies.
Do not remove the toner cartridge from its package until it is time to replace it.
caution:To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover the green imaging drum if the toner cartridge must be removed from the printer for an extended period of time.
The following illustration shows the toner-cartridge components.
Handle
Imaging drum
Protective shield
Memory chip
Figure : Toner-cartridge components
caution:If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
note:Information about recycling used toner cartridges is in the toner-cartridge box.
Remove and replace the cartridges
Open the front door.Figure : Open the door
Grasp the handle of the used toner cartridge and pull out to remove it.Figure : Remove the toner cartridge
Remove the new toner cartridge from its protective shell by tearing off the plastic strip and opening the package. Save all packaging for recycling the used toner cartridge.Figure : New toner cartridge
Remove the protective shield from the toner cartridge.Figure : Remove the protective shield
Support the toner cartridge underneath with one hand while holding the cartridge handle with the other. Align the toner cartridge with its slot on the shelf, and then insert the toner cartridge into the printer.
Avoid touching the green imaging drum. Fingerprints on the imaging drum can cause print defects.Figure : Install the toner cartridge -
Close the front door.Figure : Close the door
Pack the used toner cartridge into the box that the new cartridge came in, or use a large cardboard box and fill it with several cartridges that you need to recycle. See the enclosed recycling guide for information about recycling.In the U.S., a pre-paid shipping label is included in the box. In other countries/regions, go to www.hp.com/recycle to print a pre-paid shipping label.Adhere the pre-paid shipping label to the box, and return the used cartridge to HP for recycling.Figure : Recycle the used cartridge
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
