    Fix Windows 10 Update Issues
HP LaserJet Managed MFP E52545, HP Color LaserJet Managed MFP E57540 - Replace the staple cartridge (c models)
The following information provides details about the staple cartridges for the printer, and it includes instructions to replace them.
To purchase a package of two staple cartridges (part number Q7432A), go to the HP Parts Store at www.hp.com/buy/parts. Each cartridge holds 1,500 staples.
Remove and replace the staple cartridge
  1. Open the stapler door.
    Opening the stapler door disables the stapler.
    Figure : Open the stapler door
  2. Remove the staple cartridge from the printer.
    Figure : Remove the staple cartridge
  3. Insert the new staple cartridge into the opening inside the stapler door.
    Figure : Install the staple cartridge
  4. Close the stapler door.
    Figure : Close the stapler door
