    Fix Windows 10 Update Issues
HP LaserJet Managed MFP E52545 - 13.C, 13.D, 13.B paper jam in the duplexer
Use the following procedure to check for paper in all possible jam locations in the automatic duplexer. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. Remove Tray 2 from the printer.
    Figure : Remove the tray
  2. Pull forward on the green tab inside the tray area to release the duplex pan.
    Figure : Pull the tab forward
  3. Remove any jammed paper.
    Figure : Remove the jammed paper
  4. Close the duplex pan.
    Figure : Close the duplex pan
  5. Reinsert and close the tray.
    Figure : Close the tray
  6. Open the rear door.
    Figure : Open the rear door
  7. Remove any jammed paper.
  8. Close the rear door
    Figure : Close the rear door
  9. Press the top-cover-release button on the left side of the printer.
    Figure : Press the release button
  10. Open the front door.
    Figure : Open the front door
  11. Remove the toner cartridge.
    Figure : Remove the toner cartridge
  12. Lift the jam-access cover and slowly remove any jammed paper. Be careful not to tear the paper.
  13. Reinsert the toner cartridge.
    Figure : Install the toner cartridge
  14. Close the front door.
    Figure : Close the front door
