4JD44PA
HP Pavilion - 15-cs0049tx
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only)
36.16 x 24.56 x 1.79 cm
1.85 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion - 15-cs0049tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
