HP t430 Thin Client Specifications
Product image
Figure : HP t430 Thin Client
HP t430 Thin Client
Operating systems
Specification
Preinstalled
HP ThinPro (including HP Smart Zero Core)
Microsoft Windows 10 IoT Enterprise
Processors
Specification
Central processing unit
Intel Celeron Processor N4000
1.1 GHz base frequency, up to 2.6 GHz maximum
CPU maximum frequency is based on Intel Turbo Boost technology.
2 cores (x86)
4 MB cache
Graphic Processing Unit
12 execution units (EUs)
Intel UHD Graphics 600
Memory
DDR4 2400
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
Graphics
Specification
Supported displays (maximum)
Two
Video outputs
(1) DisplayPort (DP)
(1) DisplayPort over USB-C
(1) HDMI port
Dual displays are supported for the following video output combinations: HDMI with DisplayPort or HDMI with DisplayPort over USB-C.
Maximum screen resolution support
(2) Displays at 3840 x 2160 at 60 Hz via DP ports
(1) Display at 1920 x 1200 at 60 Hz via optional VGA port
The system should be configured with dual channel memory (two SODIMMs) for optimal display resolution performance. Dual channel memory is required to achieve maximum resolution on dual UHD displays.
Storage/drives
Specification
Type
NAND flash memory (non-volatile)
Number of sockets
(0) slots (embedded storage)
Storage capacity
16 GB on HP ThinPro models
32 GB on Windows models
Memory
Specification
Type
Single channel DDR4 SDRAM
Data transfer rate
Up to 2400 MT/s
Peak transfer rate
19,200 MB/s
Number of slots
(0) slots (embedded memory)
Capacities offered
2 GB on HP ThinPro models
4 GB on Windows models
Reserved for graphics
256 MB (default), 512 MB, or 1 GB
The system GPU uses part of total system memory. System memory dedicated to graphics performance is not available for use by other programs.
Audio/multimedia
Specification
Audio
Audio CODECs include MP3, AAC stereo, HE AAC
Includes hardware acceleration support
(1) 3.5 mm (0.14 in) headset jack (front access) that supports a headset, headphones, or an external speaker system
Video
MPEG-4 part 2 (DivX, Xvid)
MPEG-4 part 10 (H.264), Advanced Video Coding (AVC) (H.264 encode)
MPEG-H part 2, High Efficiency Video Coding (HEVC) (H.265 decode)
WMV 7/8/9 VC-1 and ASF Demuxer
Input/output ports
Specification
USB ports
(1) USB-C featuring DisplayPort over USB-C and USB Power Delivery
(3) USB-A
Video outputs
(1) DisplayPort 1.2
(1) HDMI
Only two video outputs can be used simultaneously.
Other
(1) RJ-45 Gigabit Ethernet interface
(1) 3.5 mm headset jack (side panel)
Networking/communication
Specification
Wi-Fi (WLAN)
Intel Wireless-AC 9260 with Bluetooth; M.2 module with integrated internal Wi-Fi antenna system
Intel Dual Band Wireless-AC 8265 Wi-Fi and Bluetooth 4.2 Combo 802.11ac (1x1)
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices. Wireless features, performance and support may vary depending on environmental variables such as placement, settings and firmware of the access point. Contact your wireless vendor for support.
Wired LAN
Realtek Gigabit Ethernet (GbE)
Wake on LAN
PXE
TCP/IP with DNS DHCP
Secure Socket Tunneling Protocol (SSTP) (supported with a Microsoft operating system)
Supported host environments
Host environment
Protocol
Compatiblity
Microsoft Remote Desktop Services
Remote FX (RFX) and RDP
All installed operating systems
Citrix
ICA and HDX
VMware Horizon
RDP and PCoIP
Supported protocol clients
Protocol clients
Compatiblity
Citrix Receiver
Microsoft Remote Desktop client
MS Windows 10 IoT
VMware Horizon View client
HP TeemTalk Terminal Emulator
HP ThinPro and Smart Zero Core
Free RDP
Software/security
Functionality
Application
Compatiblity
Browser support
Mozilla Firefox 50.0.1
Internet Explorer 11
MS Windows 10 IoT
Management tools
HP Device Manager
HP ThinUpdate
MS Windows 10 IoT
HP Easy Tools
HP Smart Zero Client Services
Microsoft SCCM/EDM agent
MS Windows 10 IoT
Security
SmartCard
Logon Manager
Read-only operating system
802.1x
Operating system write filter (HP Write Manager, Microsoft Unified Write Filter)
MS Windows 10 IoT
Microsoft Firewall
MS Windows 10 IoT
Additional components
HP Easy Shell
MS Windows 10 IoT
Windows Media Player 12.0
MS Windows 10 IoT
Microsoft Direct Access
MS Windows 10 IoT
Microsoft BranchCache
MS Windows 10 IoT
Microsoft AppLocker
MS Windows 10 IoT
Microsoft Sideloading
MS Windows 10 IoT
Audio/video CODEC
MP3
WMA Stereo
AAC stereo and HE AAC
Microsoft AC3 encoder 12
MS Windows 10 IoT
MPEG-1
MS Windows 10 IoT
MPEG-4 part 2 (DivX, Xvid, H.263)
MPEG-4 part 10 (H.264, AVC)
WMV 7/8/9/VC-1 and ASF Demuxer
UEFI
Revision 2.6 (addresses NIST SP 800-147 guidelines)
Software performance and support might vary depending on customer environment and backend.
Hardware security
Specification
Hardware security options
Security lock support
Cable sold separately.
Trusted Platform Module 2.0 (TPM) on Windows 10 IoT Enterprise models
HP ThinPro models do not include a TPM.
Power
Specification
Power supply
45 W external power adapter
Worldwide auto-sensing 100 to 240 VAC at 50 to 60 Hz
Energy saving automatic power-down
Surge tolerant
Physical specifications
Specification
Dimensions (W x D x H) (vertical orientation)
135 x 135 x 32 mm (5.31 x 5.31 x 1.26 in)
Volume
0.58 l
System weight
410 g (0.9 lb)
Shipping weight
1270 g (2.80 lb)
The addition of optional modules increases the weight.
Environmental
Specification
Operating temperature range
50° to 104° F (10° to 40° C)
Non-operating temperature range
-22° to 140° F (-30° to 60° C)
Humidity
Condensing
20-80%
Non-condensing
10-90%
Specifications are at sea level with altitude derating of 1° C/300 m (1.8° F/1,000 ft) to a maximum of 3 km (10,000 ft), with no direct, sustained sunlight. Upper limit might be limited by the type and number of options installed.
