    Fix HP Printer issue on macOS
HP Web Jetadmin - Uninstall HP Web Jetadmin
When you uninstall HP Web Jetadmin, the Microsoft SQL Server Express Edition instance of the HP Web Jetadmin database is also removed. You can restore the HP Web Jetadmin database if you ran the appropriate backup procedures and stored the backup files in a secure location.
To uninstall HP Web Jetadmin, perform the following steps:
  1. Go to Start > Control Panel > Uninstall a program.
  2. Right-click HP Web Jetadmin 10.4, and then select Change. The HP Web Jetadmin 10.4 - InstallShield Wizard starts.
  3. Click the Next button.
  4. Select the Remove option, and then click the Next button.
  5. Follow the instructions in the wizard.
  6. Review the MSI <xxxxx>.LOG file, where <xxxxx> is a randomly generated string. The log file is available in the following directory:
    C:\Users\<username>\AppData\Local\Temp
You can uninstall HP Web Jetadmin from the command line. For instructions, see the Uninstall HP Web Jetadmin from the Command Line white paper. This white paper is available from the HP Web Jetadmin support page (in English).
