Document ID: c05977064
Version: 1
Advisory: HP ZBook x2 G4 Detachable Workstation - ESC and Function Keys Will Not Work During POST
Release date : 13-Apr-2018
Last updated : 13-Apr-2018
DESCRIPTION
When you press the following esc or fn keys during POST on an HP ZBook x2 G4 Detachable Workstation, the key function does not work.
  • ESC: Startup Menu
  • F1: System Information
  • F2: System Diagnostics
  • F3: 3rd Party Option ROM Management
  • F4: Start Intel CIRA
  • F6: ME Setup
  • F9: Boot Menu
  • F10: BIOS Setup
  • F11: System Restore
  • F12: Network (PXE) Boot
SCOPE
Systems:
  • HP ZBook x2 G4 Detachable Workstation
Operating Systems:
  • N/A
RESOLUTION
This is working as designed. The esc and fn keys do not work during POST. Perform the following procedures to resolve this issue.
  1. Turn off the tablet.
  2. Press the power button, quickly press and hold the volume down button until the Startup menu is displayed.
  3. Press the function key.
Hardware platforms affected : HP ZBook x2 G4 Detachable Workstation
Support Communication Cross Reference ID : IA05977064
